CFD Live Particel Simulation stuttering when still
RM_9921326
3-Newcomer
I recently made some CDF-Live Simulations and thought that the particle animation is really slow.
It turns out, when dragging or rotating the part the animation is fluid.
GPU = 3080 ti also happens with 2070 Super, and 1660 TI Mobile
Drivers - Newest and i also tried the latest WHQL drivers
Win 10 and 11
I checked the Monitor and found that Creo (once the object stands still) lowers the refresh rate to about 3-5 FPS, (usually wanted) , but it also happened when a particle animation is running. When dragging the model the refresh rate jumps to the usual 250+ and the animation is smooth.
I attached a short Video demonstrating the effect (sorry for the music and outro, i tried some presets)
I searched quite some time for a config Option, but i didn't find much related to refresh rate or CFD-Live.
The few Commands i found didn't solve the issue
MFG Raimund
I encounter the exact same animation issue with live simulate on a pro laptop with an intel i7-11850H and an Nvidia RTX A2000.
Like you I still did not find any configuration that makes the animation smooth.
i literally just necroed another thread that has the same unresolved issue!! must be something to do with rendering when inactive
i also am using a 2070 super on an alienware m15r3
