Divide a Style into parts
hamdenanden3
Hi
I am modelling a joystick in Creo Parametric 2.0 with the Style feature.
Now I would like to divide the model into several parts. Normally I would make a mastermodel and extrute the remaining material away, and assembly it all in the end.
I have experienced this is not possible when I have used the Style function.
Anyone who has a good ide, or a way to solve my problem?
Best regards
EJ
Can't you project curves onto the face and trim to them?
The usual way I would think of is to have the style part as a kind of skeleton. Then you create copy geoms of the surface into several parts where you detail them.
Yes I think I will project the curves, and detail the parts. If I can figure it out I will copy the geoms.
Actually I have a problem before this, some areas of my style will not "Thicken". And I get this message
The offset value is too large. All of the surfaces become self-intersecting
or inverted at the specified offset distance.
Recommended actions:
Use "Info, Srf Analysis, Offset Mesh" to investigate the surfaces.
Redefine the offset/thickness value to be smaller, or redefine the surfaces
to be offset."
I dont really get it, or what to do?
I have figured out the second question my self. Now I will try to make it into parts.
Thanks for your help.
