Enable Volumetric flow rate & volumetric flux in section window of post processing Creo Flow Analysis. Can anyone suggest any workaround?
when will PTC introduce these variables in Creo Flow Analysis ?
Is there any development / work going on related to this subject?
Hi @rr_12092842
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Hello Rohit,
Thank you for your question!
Volumetric Flow Rate is fundamentally an integrated quantity across a surface and is not usable as a Surface Variable contour. Instead, it can be output as a value on an XY-Plot for any selected Boundaries or Interfaces. The steps are detailed here in the Post-Processing section of the Creo Flow Analysis manual:
You can find a list of the built-in outputs for Creo Flow Analysis in the online help here:
Hi @rr_12092842 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
