Generative design strange solutions
ErikClacey
I'm seeing some very strange solutions in generative design. See the image below. Fixation points at the bottom and the top is connected to a now hidden body. I have a body that divides the part as  excluded body. What I get is material being generated "pressed" up against this cutting body, rather than having material straight between the fixation holes. Any idea what could cause this?
Can you attach the model? I don't understand the issue from the screenshot.
