I want to calculate the torsional stiffness for my design, So for that I have to determine the value of angle of twist in simulation. Can anyone tell me the procedure to calculate the torsional stiffness or angle of twist in creo simulation.
Hi @PK_12801466
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry, such as:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Hi @PK_12801466
I'm not sure if there is a direct way to meet your needs. Allow me to suggest a process using Creo Simulate:
When you have the two, you can perform relative measurements on them.
Hi @PK_12801466,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
