ISO SIGN
pfadams
ISO SIGN
Hi all
Does anyone know where I can get CAD models of ISO 3864 warning
and safety triangles to put on labels.
I need the yellow triangle with lightning bolt and the one with
the exclamation mark (!)
thanx in advance
Paul
Are the ones that come with Pro/E too Mickey Mouse for your needs?
Looks like intended functionality used two methods to create a triangle.
One has a heavy line weight so the corners are broken. The other has a
wide spaced fill so that when enlarged it does not appear solid. You
could redefine the one on the left to meet your needs. And copy the
explanation mark form the other one.
Thank you, Jim Flores
Mech. designer/CAD admin.
Clinical Care Systems
Philips Healthcare
2271 Cosmos Court
Carlsbad, CA. 92011
