I just like to add a parameter called text1 for line 1 and text2 for line 2 and so forth.
When you add the text you will see there is a little check button that it can be controlled by the parameter you specify.
Then you can just make a family table of labels with whatever text you want on them as different part numbers.
In Reply to Andrew Hermanson:
One thing I forgot to mention. Does anyone else thing it would be nice to be able to add text type geometry to layers so you could hide them or control them with layer states of is it just me?
Andy Hermanson
Engineering Design Applications
tel 605.275.1040 x51114 mobile 605.310.8168
website www.daktronics.comhttp://www.daktronics.com
[cid:image001.gif@01CDA171.24B15430]
