Optimize Spring in Mechanism with BMX
SK_13639906
Hello. I am simulating one beam model which rotates around an axis.
・A clock spring is set on the rotation axis.
・In MDO, beam model start to rotates upward once it start running
I would like to explore Minimum Spring Constant K (Nmm/deg)  that allows the beam model to rotate more than 40 degrees.
(no need to change Beam model dimension)
In this case, is it possible to obtain a solution for the spring constant K with BMX?
Or any other solution in Creo?
I try setting Spring constant K as BMX Goal by using relation. But it was not explored
This problem will be solved by hand calculations. However If a solution exists for this simple problem, I will apply the method to more complex problems . (to simulate Car Seat Tumble Motion)
Any advice would be greatly appreciated.
Hi @SK_13639906
Thank you for your question.
Best regards,
Catalina
PTC Community Moderator
PTC
