Hi All,
This is my first post.
I have some complicated issue in design with Pro/E.
Let say I have plate with hole diameter 18 mm, and the 18 mm is special for M16 bolt.
Sometimes customer want push to speed up the design and I forget to check the hole and the connection is M20 bolt which is unfortunately didn't fit to the hole and become issue. In large assembly it won't appear but if check closely to the hole it would be.
Can anyone advice how to suit hole to its connection without check anymore?
Is there any parameter so if the connection didn't suit to the hole will be warning/alert from Pro/E.
ARiF
