Set up simulation Loads/Constraints color
amedina-2
I search for any API function that set up color for simulation objects like constraints and loads, default creation dialog provide this. I found only example for Creo Parametric objects, try to  use it for Simulation but it have no effect.
ProColor yellow;
yellow.method = PRO_COLOR_METHOD_RGB;
yellow.value.map.red = 1.0;
yellow.value.map.green = 1.0;
yellow.value.map.blue = 0.0;
ProGraphicsColorModify(&yellow,NULL);
example or API function name will be useful, thanks.
I only now the functions to color features, solids, surfaces
What you do is to change the std. color map. I don't know if thats a good idea. If you only want to do that you can also change it in config.pro I think.
To change the color permanent:
I use old prodb functionality:
prodb_set_surface_props((Prohandle)setAppearance_mdl, SEL_3D_SRF, p_feature->id, 0, &psp);
but there is also a Toolkit function, I need to be Wildfire 4 complient but I think the rework as a TK Command is in Creo 2.0 working ... so that's why.
You can define here from an RGB value and push it directly to whatever you want.
Br,
Eike
