Structural Nonlinear analysis of an assembly incl. rubber part
- December 16, 2019
- 1 reply
- 1682 views
Hi everyone,
I'm looking for help to solve my analysis now. Our company has bought extended license of Creo Simulate to be able to run a contact analysis incl. rubber part. I have been trying to solve this by myself and almost gave up on this. So I hope someone could share their experience with me=)
The analysis I need to run as follows:
1) Assembly consists of:
- a valve house made of Ductile iron GGG-50.
- a wedge insert made of Ductile iron ggg-50 and covered with a rubber layer (This is a subassembly)
2) I could cut 3/4 part of this assembly and use symmetry constraints to save some time.
3) Valve house has fixed constraint at the bottom.
4) There are contacts (component - component) between the valve house and rubber (covering the wedge insert).
5) Wedge insert and wedge rubber are bonded (component - component)
6) There is not force or pressure applied in this case but the wedge need to go down to meet the contact surfaces in the valve house. Or maybe there is a much easier way to conduct this analysis but I don't know yet.
I need to find out a behaviour of the rubber when the wedge is totally down in the valve (sealed). How much deformation I will get? What are the weakest places with most deformation / stress?
