To create my own Balloons & Mechanism
1. I have a assembly which need to create Mechanism.How can I use Drag Components to check interference (highlight red),but I need my model stop at interference? Maybe exclude the Playback that I can't use this function. I need to check interference immediately.
2. I need to create Balloons manually not by autonmtically. I'd like to follow my own mind. The A Bom follows assembly in sequence.It's not my mind. I need like the B Bom don't follow assembly in sequence.
How can I set the B Bom's setting ?
3. I need to check my assembly interference, but I have over one hundred parts of assembly. I need to reserve the interference result beacuse I always have a lot of interferences. I resolve one interference then I forget other places of interference. I have to calculate again. It wastes my time.
If anyone can help me here I'd greatly appreciate it, thanks!!
