replace publish geometry reference
mparaboschi
2-Explorer
How to replace a "publish geometry" without losing all the references?
I need to replace the "published geometry" with a new one that is a copy of the original one (I just need to change the name). When I used the "edit definition" and select the new part I get a message error saying "all the references will be lost" (see attached pictures).
I even try to use the "save as" function in windchill, but I didn't manage to get it done.
I'd appreciate any suggestions
0 REPLIES 0
