Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I want to ask one thing about arbortext editor, the question is can we integrate or link a convert which i have made in excel into arbortext so that it will be easy for us to convert any values without closing or minimising arbortext editor .
