ACL code not working
epichelp
6-Contributor
Using acl scripting in Arbortext Editor 6, How can an sgml file be opened and then save it as xml?
The doc_open method below returns a document identifier.
Providing this document identifier to the doc_save function saves an empty xml file.
Sample ACL Code:
#Open a sgml file
#0x200 - Open the document without loading a stylesheet.
$sgml_doc = doc_open("file.sgml", 0x200)
#save as xml
#0x0020 - Write the document as an XML document
doc_save($sgml_doc, 0x0020, "file.xml")
What should be done differently?
Did you not see my reply to your earlier thread?
http://communities.ptc.com/message/243117#243117
There is a different ACL command that converts SGML to XML.
We are executing ACL files via Arbortext Editor Command Line (ex: “source acl_file.acl”).
A document identifier had to be provided to doc_kind() function to allow it to function for the document opened by doc_open().
The following code sample produces an empty xml file. What are we missing?
Sample Code:
cd "c:/folder_to_sgml/"
$sgml_doc = doc_open("sgmlfile.sgm", 0x200)
message "sgml document identifier: $sgml_doc"
$xmlName = "xmlfile.xml"
if (doc_kind($sgml_doc) == "sgml") {
message "document type is: sgml"
save_as -xml "$xmlName"
# Close SGML File
close($sgml_doc)
TimPhelps
(To:epichelp)
Why did you switch from using doc_save to using save_as?
Tim
TimPhelps
(To:epichelp)
Did you get this issue resolved?
Was one of the posts helpful or did one answer your question?
