ACL to restrict attribute values for user selection
abolton
I want to be able to restrict an attribute's enumerated values presented for user selection without modifying the XML schema - can this be done with ACL?
Hi Andrew--
Sure, you can do this. Use the "modify_tag" doc callback to fix up the attribute value list, something like this:
function mt_callback(doc, oid, win, op) {
  if (op == 1) { return 0; }
  # get doc ID
  local dlgdoc = _xmldlg::getDialogDocument(win);
  local tagname = oid_name(oid);
  # get list of attrs with enumerated values (comboboxes in modify attrs dlg)
  local attrs[], a;
  oid_xpath_nodeset(oid_root(dlgdoc),attrs,"//combobox");
  # find the attr we want to modify
  local values[], v, alias, attr;
  for (a in attrs) {
    attr = attrs[a];
    attrname = oid_attr(attr,"id");
    if (//attrname is attribute to be modified//) {
        # hide unwanted values
        local items[], i;
        oid_find_children(attr, items, "listitem");
        for (i in items) {
            local label = oid_attr(items[i],"label");
            if (//label should be removed//) {
                 oid_delete(items[i]);
Then, somewhere in your initialization code, make sure you add the callback:
doc_add_callback(0, "modify_tag", "mt_callback");
Replace the bits between double slashes //..// with proper tests and this will give you better control of the attribute values without having to modify the schema.
--Clay
Thanks Clay for the fast response (and documented code!).  I will try this and get back
