Hello experts!
Ok, so I've been playing with the jvm and I would like to know the
flexibility provided by Arbortext in order to modify or not use the
jvm.dll provided by default in the installation folder. Until now I have
the idea that by first instance Arbortext Editor will always use the one
provided by default, is that correct? Do you know how many ways do I
have in order to personalize my jdk version according to my Arbortext
Editor? Is that possible? and also I would like to know, is that
recommended? In my case I have the Arbortext 6.0 32-bit and in my
computer I just installed the 32-bit Java7.
Thank you soo much for your time and suggestions/responses. Have a
wonderful day! 🙂
P.D. (I would like to know also if it's possible to know if my Arbortext Editor is using a 32-bit or a 64 version. Do you know any command to get this information using ACL?)
Paulette Zorrilla
Just a note that Arbortext 6.1 supports Java 7.
Regarding testing whether the version is 64-bit, there isn't an environment variable that explicitly denotes this. However, if you've installed Arbortext into the default location (Program Files vs. Program Files (x86)), you could extrapolate the version based on the installation directory. The variable to try would be$aptpath (or $aptbinarypath to get the full path to the exe).
-Jeff
Paulette Zorrilla
Guys! Maybe my next question would be more related with my computer's environment, however, when I was trying to set my jvm manually using the following ACL command "set javavmpath" I apparently didn't receive any positive response, since Arbortext seems to give priority to the jdk installed on my computer, the jvm that I was trying to set was in a different directory and of a different version of the which one installed on my computer; so I was thinking, How can I tell to Arbortext to ignore the Java version installed on my computer and use anyother? Any ideas?
Best regards!
Paulette Zorrilla
