We have a macro that inserts the file name of the file onto the illustration. Is there a way to make the text background white automatically? We currently do it manually after we add the text by the macro. If I try to create a macro the option to modify the text background is greyed out.
Thanks to PTC support for explaining some things to me
Macro Add_FileName
Define h AS Integer
Define w AS Integer
Define el AS Element
w = activeDoc.window.pageX-2
h = 2
#Message "The height is " + h
#Message "The width is " + w
#Added below command to ensure number is placed on the Illustration number layer
ACTIVATE LAYER "Illustration Number"
Select none
Text Align Left
Text font 'Calibri'
Text size 6
Create Text w h stripext(activeDoc.name)
el = activeDoc.firstSelectedElement
el.text.backfill_color.type = "rgbValues"
el.text.backfill_color.rgb.red = 255
el.text.backfill_color.rgb.green = 255
el.text.backfill_color.rgb.blue = 255
el = el.nextSelectedElement
Rotate selection w h 90
Select none
End Macro
Came across this today in the support search https://www.ptc.com/en/support/article/CS203689?&language=en&posno=1&q=text%20background&ProductFamily=Arbortext&source=search
How do I get it to find a text string. We have a seven digit numeric code that we use for our image number. Currently it works if I enter a 0
Macro debenedetti # recorded with PTC Arbortext IsoDraw 7.3 Select none Select if Text is equal to '0' Select if Text contains '0' MESSAGE activeDoc.selectedElements DEFINE el AS element el = activeDoc.firstSelectedElement IF (exists(el ) = false) THEN MESSAGE "No element in the active document!" Else WHILE (exists(el) = true) el.text.backfill_color.type = "rgbValues" el.text.backfill_color.rgb.red = 0 el.text.backfill_color.rgb.green = 255 el.text.backfill_color.rgb.blue = 0 el = el.nextSelectedElement END WHILE END If Select none End Macro
Any suggestions for me?
Bryon
Maybe I should modify my original macro instead This creates a text then places it in the bottom right corner and then rotates it 90 degrees. If I add the text backfill as suggested in the above sample from PTC. What do need the element to be as I want it to add the background to the selection which is the text.
Add_FileName
Define h As Integer
Define w As Integer
h = 2
#Added below command to ensure number is placed on the Illustation number layer
Select none
Text Align Left
Text font 'Calibri'
Text size 6
selection.text.backfill_color.type = "rgbValues"
selection.text.backfill_color.rgb.red = 255
selection.text.backfill_color.rgb.green = 255
selection.text.backfill_color.rgb.blue = 255
End Macro
Bryon
Macro Add_FileName
Define h AS Integer
Define w AS Integer
h = 2
Select none
Text Align Left
Text font 'Calibri'
Text size 6
Select none
End Macro
Thanks for sharing the solution!
