Does anyone know if there is an existing shortcut/hotkey for Tag Templates in Arbortext 5.4? If not, then is there a way to create custom shortcuts/hotkeys?
The acl command to assign a shortcut to the tag templates is:
menu_change .Tools.Tag_Templates... -key 'shortcut'
where shortcut is some key, like 'control-y'
Hi Kenneth,
Are you looking for a shortcut to just bring up the tag tamplates dialog box, or something more to insert a specific tag template to the location where your cursor current is?
Hi Rafel,
After I posted my original question, I find out that I can pull up the Tag Template dialog box by seperately selecting - Alt, T, L. It's definitely quicker than clicking Tools, Tag Templates.
Although, do know of any other hot keys that will either bring up the Tag Templates dialog box or insert a specific Tag Template?
Thank you,
Ken
I believe it's possible to do it using the ACL, but it's a complex way and needs a good knowledge about ACL.
Robson is correct. This would likely be enacted by ACL. You can get some good info looking into the term keymap in the Help Center, such as the article:
All,
Thank you for your assistance. I believe adding this shortcut will help my team be more efficent.
Your help is greatly appreciated,
Ken
