I made some DITA dtd constrants for figure and table. When I updated with arbortext editor changes not reflecting in editor. Do I need to change .acl and .dcf file in arbortext? Anybody can help?
Roopesh
Hi Roopesh,
You might want to force a recompile by typing compile_doctype at the command line.
You will then need to specify the Document Type Path and the top level DTD tag within the Compile Document Type dialog.
Then see if the new changes you have made to the DTD are reflected in the Editor.
This normally works for me.
Andy
