We are troubleshooting an issue impacting community login, and it may be intermittently unavailable. Sorry for any inconvenience.
When we launch the print preview the file is composed as a pdf automatically. How do I turn this off?
I noticed that my Arbortext print preview does not look like the user beside me. Attached are some screen shots of the two different windows.
Item #2 in the screen shot produces the correct view of the print preview.
Does anyone know how it is that we have different looks to the print preview? How can I get my setup to be like Item #2?
Actually, we realized that the print composer was not installed correctly. Re-installed the print composer and it works.
Not sure if this will belp but, Under Tools, perefences, advanced, find usedistiller and see if it is set to on. It is probably set to off which uses the internal pdf generation program included in the product.
Bryon
Ps make sure you set your Acrobat pdfer as your defualt printer
