Arbortext Editor, Styler, Publishing Engine 8.2.0.1 have released!
plutsky
This release supports the ability to run Editor or Styler 8.1.x.x and 8.2.0.1 on the same system.
It also contains bug fixes.
8.2.0.0 will no longer be available for download.
PTC recommends that customers who have previously downloaded 8.2.0.0 should uninstall 8.2.0.0 and move to 8.2.0.1.
Hi - Can you pls mention which SPR/bug is fixed other then having ability to run 8.1.x.x and 8.2.0.1 on the same system.
regards,
Gaurav
plutsky
(To:GK_9183824)
It was an issue with the Document Type Viewer (Tools->Document Type Viewer).  However we are concerned that it affects other areas as well, so we recommend customers to move to 8.2.0.1.
Patti
