Software: Arbortext Editor 5.4 M080
Hello
I'm receiving the error as defined in the subject field a couple of times each month. Has anyone had the same issue and if so, how did you resolve it?
I am currently unable to upgrade to newer version, so hopefully it's possible to resolve without having to do so.
Articles:
Thank you, VladimirN.
Unfortunately, I don't have access to this article as I don't have an active maintenance subscription.
Dear Customer,
What activity you're performing in Arbortext Editor causing this error to be thrown?
Manpreet Singh
Hello!
Usually the error is thrown when creating a PDF of the document.
BR
Dear Customer,
Based on the error message you have shared, you can try the below to see if that resolves your issues.
Issue description is one of the below:
"[A31641] unexpected error within timer."
Proposed Resolution:
For sample:
P.S. - Please take the backup wherever it's applicable.
Manpreet Singh
Dear Customer,
Did the provided suggestion helped resolving this issue? Thanks.
Manpreet Singh
