I'm trying to figure out the availability of Arbortext Layout Editor. I filled many times the form but can't seem to get a hold of any salespeople from PTC, I fill out a form and never hear from them. Does anyone know if this option is available? If not, can I an email of someone that can actually give that information?
Dionysis
Hi Dionysis
It is available as a Document Editor/Paginator in conjunction with ALD built templates normally from specialist resellers.
We can also offer new user and existing ALD template migration training & consulting if required.
https://www.tformat.com/arbortext-layout-editor-ale/
Best regards
ALE is intended to be used with ALD for automation of typesetting and publishing tasks. Our company, GPSL (www.gpsl.co), is an approved PTC partner who can help and advise.
Thank you very much for the informative response! I will see your link and if I need something I will contact you!
Hi Dionysis
Best regards
I appreciate your helpful reply! If I need more guidance, I will reach out to you.
