Does anyone know if APE 8.1 is compatible with Tomcat 9+ ? The install documentation specifically mentions Tomcat 8.5 and when I try to install the APE with Tomcat 9, the "Tomcat is installed on this system. Do you want to integrate PE with Tomcat?" does not seem to appear during the install.
Thanks.
APE 8.1 is not supported with Tomcat 9+
Kind regards
