I have a xml content has characters in china, Japan and Korean languages, generated pdf showing blank in place of these characters.
What are pre requisites to support these languages on publish server(Arbortext Publishing engin 5.3).
i have configured fosi file as below and server has installation of Arial Unicode MS
<font style="serif" famname="Arial Unicode MS" size="11pt" posture="upright" weight="medium"
width="regular" offset="0pt"/>.
Does the server also require installation of East Asian language pack or any other configuration required?
Several things to try (from another thread: http://communities.ptc.com/message/16729#16729):
More:
When I pinged PTC, several questions came back:
If the user is not using the CJK fonts (e.g., MS Mincho), the server shouldn’t need them.
Their final reccommendation was to tell you to call Support.
