Arbortext Publishing Engine - Accessing Activation files from network share
We trigger APP sub-process in Arbortext Publishing Engine through activation files. When we place the activation files in local drive, PE sub-process is running properly. But when we place activation files in network share PE couldn't be able to take that Job.
Can we have some suggestions on that.
Note:
1. We are running TOMCAT server as a domain user which has all rights to the network server path
2. We are launching PE Sub-process as a domain user which has all rights to the server path. When input files are placed in network share, PE sub-process is able to take those files and process those files. But the activation files, files given in <input> and <output> tags of activation files are not identified by PE.
