Hi, Did anyone work with ACD - Arbortext content delivery (formerly called as Servgistics), which falls under the deliver model of the overall create-manage-deliver thread. Any insights or documentation references on its business case and possible integration with Windchill would be helpful. I would like to understand if there is a way to downstream data from Windchill to ACD for various stakeholders reference. Thanks in advance.
From "Help Center" - "Understanding the Publishing Process": https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/sim_customize/sis8100.html
Thanks but this did not help much. Any documentation you can point me to, that talks about the integration with Windchill PDMLink?
Thanks a ton. This is helpful.
You're welcome.
