We are using Arbortext editor 5.3 to author content and storing in documentum, if we place cursor after the last element, on save in epic it is adding processing instruction <?Pub Caret?> after last element, this is causing issue in documentum considering this as element.
we want to to remove processing element if exist as a last element, please let me know how to remove.
vittal
This question is asked so often, it's part of the Adepters Archive:
http://www.adepters.org/index.php?title=Those_Pesky_PIs
Turning off the PIs is easy. You change an advanced setting in the preferences:
set writepi=off
It's documented in help topic #1587.
BTW: You'll have faster response time using the adepters mailing list:
The PTC/User portal (http://www.ptcuser.org) hosts the long-running Adepters mailing list. This list started in 1996 and has always been monitored by the PTC/Arbortext software engineering staff. Many long-time users and tools folks also regularly monitor the list. If you have a question, it's a really good resource as questions generally get answered within 24 hours. Beginning and advanced questions encouraged.
The List Email Address is: -
You can join the list from the PTC/User portal: http://portal.ptcuser.org/p/fo/si/topic=21
