Arbortext import remembering configuration
ptc-4180382
Help! Can anyone tell me how to make sure that the Arbortext Editor (v6.0 F000) Import a document dialog remembers the location of the mapTemplate files separately from the location of the file to be imported. It only seems to remember the last location used which is very annoying as the mapTemplates and documents are in different locations.
Also is there any way to configure the default file type to be docx in this dialog.
Thanks in advance.
pnagai
(To:ptc-4180382)
Unfortunately, I have no idea. (Not a DITA user.)
Your best bet, if you haven't solved this or moved on already, is to join the Adepters mailing list where lots and lots of Arbortext users, admins, and developers (including many familiar with DITA) hang out 24/7/366 (it is a leap year, you know!). Information on joining that list (as well as pointers to lots of other Arbortext resources) can be found here:
http://blog.single-sourcing.com/top-arbortext-resources
Good luck!
