Arbortext logging out of Oracle
ptc-4568165
I'm using Arbortext 6.0 F000 and using it to log into Oracle.
If there is no database activity for a while (30 mins roughly), i lose my connection with oracle. Is there a setting somewhere which details the time for disconnecting Arbortext from Oracle?
Many thanks for any help
pnagai
(To:ptc-4568165)
Hi Kelvin,
I don't work with Oracle so I can't say anything for sure. My guess, though, is that this is a configuration item on the Oracle side. This is how it works for our Documentum integration. (I am assuming you are using and referring to an Oracle content management system.)
Your best bet, if you haven't solved this or moved on already, is to join the Adepters mailing list where lots and lots of Arbortext users, admins, and developers hang out 24/7/366 (it is a leap year, you know!). Information on joining that list (as well as pointers to lots of other Arbortext resources) can be found here:
http://blog.single-sourcing.com/top-arbortext-resources
See also:
http://www.single-sourcing.com/company/social.html
Good luck!
