Hello again! 😃
I've checked my code and I'm pretty sure is because I'm using thewindow_destroy() command, but I don't know why is destroying the main window since the parameter that I send is one corresponding to a customized window created by me. however, does anybody know if I can identify if the window that I'm trying to destroy is not the main window and avoid this error?!
Thank you very much!
Paulette Zorrilla
