Hi evrerybody,
Here is my probleme, i try to create automatic attribute in macro like adding colors, pens, linestyle etc... that part works good, but in some case some pens, colors, already exist so it bug my macro... I try to modify macro to fit something like that:
If color "ABC" does'not exist...
Add color "ABC" then
If color "DEF" does'not exist...
Add color "DEF" then...
and same for pens, linestyle, shadows, etc.
Many thanks for support!!!
PS; hers goes my actual macro under error example
Macro Properties
DEFINE name AS string
name = "Set All Properties???"
MESSAGE name
# Attributes/Pens
App.window.pageY = 279.39
App.thickthin.upTo1 = 20
App.thickthin.upTo2 = 40
App.thickthin.useThickThin = false
App.shadow.shadowWidth = 1.02
# STD Pens
App.pens["Thick"].width = 0.61
App.pens["Thick"].switchPen = "Thick"
App.pens["Medium"].width = 0.36
App.pens["Medium"].switchPen = "Medium"
App.pens["Thin"].width = 0.18
App.pens["Thin"].switchPen = "Thin"
App.pens["Center line"].screenColor = "{RGB 0 0 0}"
App.pens["Center line"].width = 0.18
App.pens["Center line"].shadow = "Autom. Long"
App.pens["Center line"].switchPen = "Center line"
# Attributes/colors
App.colors["White"].kind = "RGB_color"
App.colors["Black"].kind = "RGB_color"
Add color "Blue"
App.colors["Blue"].kind = "RGB_color"
App.colors["Blue"].color.type = "rgbValues"
App.colors["Blue"].color.RGB = "{RGB 0 0 255}"
Add color "Green"
App.colors["Green"].kind = "RGB_color"
App.colors["Green"].color.type = "rgbValues"
App.colors["Green"].color.RGB = "{RGB 0 255 0}"
# New Pens
Add pen "Extra Thick"
App.pens["Extra Thick"].screenColor = "Black"
App.pens["Extra Thick"].width = 0.81
App.pens["Extra Thick"].style = "Solid"
App.pens["Extra Thick"].shadow = "$ISO_NOSHADOW"
App.pens["Extra Thick"].switchPen = "Extra Thick"
App.pens["Extra Thick"].color.type = "colorRef"
App.pens["Extra Thick"].color.color = "Black"
App.pens["Extra Thick"].color.tone = 1
Add pen "Hidden long dash pen"
App.pens["Hidden long dash pen"].screenColor = "Black"
App.pens["Hidden long dash pen"].width = 0.18
App.pens["Hidden long dash pen"].style = "Hidden line"
App.pens["Hidden long dash pen"].shadow = "$ISO_NOSHADOW"
App.pens["Hidden long dash pen"].switchPen = "Hidden long dash pen"
App.pens["Hidden long dash pen"].color.type = "colorRef"
App.pens["Hidden long dash pen"].color.color = "Black"
App.pens["Hidden long dash pen"].color.tone = 1
# Attributes/Styles
App.linestyles["Solid"].startMark = 1
App.linestyles["Solid"].endMark = 1
App.linestyles["Solid"].type = 0
App.linestyles["Solid"].pattern[1] = 0
App.linestyles["Center line"].startMark = 1
App.linestyles["Center line"].endMark = 1
App.linestyles["Center line"].type = 1
App.linestyles["Center line"].minEndLength = 0
App.linestyles["Center line"].pattern[1] = 6.34
App.linestyles["Center line"].pattern[2] = 0.63
App.linestyles["Center line"].pattern[3] = 1.27
App.linestyles["Center line"].pattern[4] = 0.63
App.linestyles["Center line"].pattern[5] = 0
App.linestyles["Center line"].pattern[6] = 0
# Attributes/shadows
Add shadow "Autom. Long Thick"
App.shadows["Autom. Long Thick"].start = 3
App.shadows["Autom. Long Thick"].end = 3
App.shadows["Autom. Long Thick"].width = 1.62
App.shadows["Autom. Long Thick"].color.type = "colorRef"
App.shadows["Autom. Long Thick"].color.color = "White"
App.shadows["Autom. Long Thick"].color.tone = 1
End Macro
you could try this for the pens..........
if (exists (activeDoc.Pens["LeaderWithMask"]) = false) then
ADD PEN "LeaderWithMask"
else
end if
managed to work this out.................
if (exists (activedoc.colors["MY_COLOR"].name) = false) then
Define MY_COLOR as ColorSpec
MY_COLOR.type = "rgbValues"
MY_COLOR.rgb.red = 0
MY_COLOR.rgb.green = 255
MY_COLOR.rgb.blue = 255
Add color "MY_COLOR_Name" MY_COLOR
else
end if
<You would think that PTC would have someone to answer these questions!!!>
>There isnt a lot of traffic thru this message board that would drain their resoursces!!!!<
I'm still stuck...
i need to add in this one something like that...
IF (exists (pen["Extra Thick"]) = false) THEN
but if exist, modify as per...
and go next pen to add...
IF (exists (pen["Hidden long dash pen"]) = false) THEN
and next one...
