I have been confused for a few days. If I publish a bookmap into PDF with my self-defined style-sheet, the book-title and the front-matter will appear twice! They will appear at the start of the book (It is correct), and appear again at end of book (It is not what I expect).
However, if I publish the bookmap file with default style-sheet, the result is correct—they just appear at the start. I try to adjust the style sheet many times. It seems I didn’t know where to solve it.
I don’t know how to control it – how to remove them from the end of the books. Can somebody help to answer it?
Hi Kelvin,
You may want to start by comparing the two stylesheets on the top-level element, looking at the gentext tab.
You can also check out the pageset gentext, in case it's defined there.
I also notice you mention it's a bookmap. Are you using 'Edit Resolved Document' to make the changes, and see how they work out?
Hi Kelvin,
Hi Rafael,
The issue has been solved with your advice. I used ''Edit Resolved Document'' and found an element flattenedmap. It is the hidden element cause twice appearance. I added flattenedmap element in style sheet and set it as 'hidden' sytle, the problem was then fixed.
Thanks for help!
