Bug??
I've been testing an ACL script that uses the function inside_tag(). It
seems to have a bug. If I test for an element name that has a 'dot' in the
name (e.g., <dtd.frag>) it will not recognize when it is inside the tag.
I've tested this with a couple of different element names both in the script
and from the command line and get the same result which is a failure.
Has anyone else found this to be true? And if so does anyone have a work
around.
Many thanks.
Lynn
around.
Many thanks.
Lynn
