I have a customer who wants a TOC created using content from seperate SGML files.
It is possible to generate one large SGML file manually from each of the individual files within a chapter element and easily create the TOC this way but the customer wishes to keep all the filesseperate.
Other than writing loads of ACL to open each of these files in turn, search for the section, extract it, and copy into current document, and then extract the necessary content, Is there a quick and easy alternative method for doing this ?
Hi Lynn,
If you could send me the FOSI you did that would be great.
Andy
