i need to make changes to our DTD and all the instance files that use the DTD for our product documents that Are stored in Windchill. Does anyone know of a way to loop through the documents in a library and run a transform, either XSLT or ACL, then check in the resulting document as a new revision? I'd rather not manually checkout/edit each file just to apply a script.
