Can I change the resolution / accuracy of Isodraw numbers?
ttea
7-Bedrock
I'm trying to write a macro that rounds numbers. The code asks users for a number, and the macro rounds to 2 after the decimal place. First of all, I'd like to know if Isodraw has a built in round function. That would save me some time. I searched the 7.2 IML Reference (even though I'm using 7.3 because I can't seem to get access to 7.3 IML) and there didn't seem to be a built in round function. Nonetheless I proceeded to write a rounding submacro which takes a user input for a number and rounds the 2nd digit after the decimal. However I noticed that my numbers were often altered after I input them. And so I used this text macro to test it:
macro numtest
define number as float
define numasstring as string
number = get float "Number"
numasstring = number
message numasstring
end macro
When I input 8.591, I get 8.59.
Similarly,
8.592 --> 8.592
8.593 --> 8.593
8.594 --> 8.593
8.595 --> 8.595
8.596 --> 8.596
8.597 --> 8.596
8.598 --> 8.598
8.599 --> 8.599
8.600 --> 8.599
It seems like the resolution of Isodraw's numbers are set somewhere. Why does Isodraw do this, and how can I change the resolution / accuracy of the numbers?
thendricks
(To:ttea)
First, not aware of a way to control number of places for a float. Second, it actually appears to be a bug.
I took a slightly modified version of your macro...
Macro test
    number = 1.555
    message number * 2
End Macro
Which comes out to 3.109. If I switch it to 1.5555 as below...
Macro test
    number = 1.5555
    message number * 2
End Macro
I then get 3.111 which is correct.
I guess I've never had to get to that level or the inconsistency was just never caught by our users. You may want to contact support.
Note that I'm on 7.3, M031 build 1.
thendricks
(To:ttea)
Macro test
    number = 1.555
    message number * 2
End Macro
Macro test
    number = 1.5555
    message number * 2
End Macro
ttea
7-Bedrock
(To:thendricks)
Thanks for replying, Trevor. I'll try contacting customer support.
For anyone who is interested, I'll also post my rounding code when it's finished. It's been giving me a bit of trouble so far.
ttea
7-Bedrock
(To:ttea)
Here is a rounding submacro for anyone who is interested.
To run it you can just use:
result = RUN round(number, place)
where number is the number you want to round, and place is the rounding place after the decimal.
E.g.
result = RUN round(8.599,2) will return 8.60
result = RUN round(8.599,1) will return 8.6
result = RUN round(8.599,0) will return 9
It can currently handle 0, 1 and 2 places after the decimal, and can probably be modified to do places before the decimal, but  that went beyond the scope of my purpose.
If anyone can see a way to improve this, let me know!
submacro round(float number, integer place)
# This macro is used for rounding to 0 decimals, 1 decimals or 2 decimals.
# The format goes: round(number, place) where number is the number you want to round and place is 0,1 or 2.
# This is used in conjunction with mm_on_top and inch_on_top to round the converted result.
define numstring as string
define newnumstring as string
define placefactor as integer
define length as integer
define decloc as integer
define rounddigit as integer
define rounder as integer
define rounddigitloc as integer
define OSBRD as integer
define roundednum as string
define roundeddecloc as integer
define newplace as integer
define ninefactor as integer
define decfactor as integer
newnumstring = number
#message newnumstring
numstring = number
decloc = find(numstring,'.',1)
length = len(numstring)
if (decloc = 0) then
newnumstring = numstring + '.'
numstring = newnumstring
end if
if (length-decloc < 2) then
while ((length-decloc) < 2)
  newnumstring = numstring + '0'
end while
end if
if (place <= 0) then
placefactor = place-1
else
placefactor = place
end if
rounddigit = mid(numstring,decloc+placefactor,1)      #Change -1 --> +1
ninefactor = 0
rounddigitloc = len(left(numstring,decloc+placefactor-ninefactor))    #Change -1 --> +1
rounder = mid(numstring,rounddigitloc+1,1)
if (rounder = ".") then
  rounder = mid(numstring,rounddigitloc+2,1)
# message "decimal reached"
end if
if (rounder < 5) then
  roundednum = left(numstring,decloc+placefactor)      #Change -1 --> +1  #DONE
end if
if (rounder >= 5) then
  if (rounddigit = 9) then
   while (rounddigit = 9)
    ninefactor = ninefactor+1
    rounddigit = mid(numstring,decloc+placefactor-ninefactor,1)
   # tempnumstring = ninefactor
   # message "nine factor is now " + tempnumstring
    if (rounddigit = ".") then
    end if
    newnumstring = ninefactor
   # message "current ninefactor: " + newnumstring
   end while
   OSBRD = decloc-rounddigitloc-1
   number = rounddigit
   newnumstring = number + 1
   number = newnumstring
   newnumstring = left(numstring,rounddigitloc-1) + number
   roundednum = left(numstring,rounddigitloc-1) + number
   if (ninefactor > 0) then
    if (OSBRD > 0) then
     for number = 1 to OSBRD
      newnumstring = roundednum + '0'
      roundednum = newnumstring
     end for
    end if
    roundeddecloc = find(roundednum,'.',1)
    if (place > 0) then
     if (roundeddecloc = 0) then
      newnumstring = roundednum + '.'
     end if
     newplace = len(roundednum)-roundeddecloc
     while (newplace < place)
     end while
    end if
   end if
  else
   number = rounddigit+1
  end if
end if
return roundednum
end submacro
