Is there a way to clear the PE template cache?
Probably this one:
• class com.arbortext.e3.TransformedStylesheetCache, ID stylesheet-cache. Caches transformed stylesheets in anticipation of composition requests
I'm finally to the point I can edit some stylesheets located on the PE and...it keeps caching them. I even deleted the one I'm working on and it still says there's an error on line 7!
I don't have access to the PE, took an act of Congress to get IT to restart it once...and there is this really nice Advanced Transaction Options box but the docs (as far as I've found) say to enter whatever your PE administrator tells you to.
Thanks!
Thanks for your help.
We don't appear to have Tomcat installed on our Windows server which makes tracing down errors...interesting.
I was able to do it with the PE "homepage" at http://localserver:8282/e3 via the Reload Subprocesses link.
At some point, limited access to the PE should be granted to the editor so that large shops with super-tight IT can't totally cut users off from the PE. You can change the composer log file via the command line in the editor already - clearing cache and buffers sounds like it would be easy to add and a real help to some of us developers...not to mention things like restarting the PE.
I say you can change the logging settings...I can't get it to log more than the log file name (creates a zero byte file) to my local drive.
John
