Dictionaries
berard
Dictionaries
I have created a custom user dictionary using a text wordfile, but it
doesn't seem to be working. I was wondering if anyone might be able to
point out what I'm doing wrong.
From the command line, I ran:
"c:\Program Files\Arbortext\Editor\bin\userdict.exe" -v -add -dict 2009 -f
2009s.txt
This used the 2009s.txt file in the local directory, and created a
dictionary file:
C:\Program Files\Arbortext\Editor\lib\proximity\userdict\2009.eng
I moved this file into: custom\dictionaries
Then I updated my DCF to include the following entry:
<options allowapplicationtoolbar="no" allowcomposestylesheetlist="no"&lt;br"/>allowFosiMod="yes" allowTouchup="yes" dictionaryName="2009" protected="no"/>
For some reason, even though I modified the original wordfile to remove
"e.g." and replaced it with "eg" (a company style decision), spell check is
still suggesting a correction to "e.g.".
I also tried using dictionaryName="2009.eng"... still no dice.
Any thoughts/suggestions appreciated.
keith
ashah
(To:berard)
Hi Keith,
I have only just seen your query but here goes anyway.
I set up customised user dictionaries in a slightly different manner:
For words that are acceptable, like your "eg", you set up a text file (dictionary) containing them. This user dictionary is then referenced by the environment variable APTSPLACCEPT. I have my setup on local, so the variable goes:
APTSPLACCEPT
C:\custom-doctype\dict\spell_check.txt
The cool thing about this is that you can set up a similar reject dictionary as well:
APTSPLREJECT
C:\custom-doctype\dict\spell_reject.txt
Words in this dictionary will be red-underlined in Epic.
So I guess you'd put e.g. in here and it would be flagged.
Ali.
berard
(To:berard)
Thanks, I'll give it a shot.
