Enable/disable XUI Button
pzorrilla
Hello experts, amateurs and everybody!! 😃
I have been investigating about how to enable or disable an XUI button.
I was thinking that maybe this is possible using the dlgitem_set()
command, however I'm not pretty sure how to do it 😞 Does anybody know
more about this area? Thank you so much in advance.
Paulette Zorrilla
Assuming the button will always display but be active or inactive based on
some logic, I use:
dlgitem_activate($win, $button_id)
dlgitem_deactivate($win, $button_id)
If showing and/or hiding the button entirely is your goal, that's
different. My code above will "gray" the button when it is deactivated and
make it non-user-selectable.
On Tue, Aug 20, 2013 at 2:22 PM, paulette zorrilla <
> Paulette Zorrilla
Paul, thank you so much. It works! What I was needing is was only to enable or diable the button.
Paulette Zorrilla
