Dear Users,
Is it possible to add a frame for a element that is styled to be a block .
So that the pdf looks like surrounded with frame (customisable) for the specific element. I am bit lost while trying it with APP SOurce Edit.
ps suggest a better alternative or share info on achievieng using APP.
Regards.
Sriram Rammohan
Have you thought of placing the element in a single column, single row table with frame on?
APP supports customisable borders, but when you say frame that sounds quite decorative. Depending upon the design you may have to use a background image to achieve the effect. If you need further advice from APP experts, try the 3B2users group at Yahoo!.
