I have a problem with displaying images in *.pdf format in Arbortext Editor.
The files with standard extensions (*.jpg, *.eps, etc) are displayed in Arbortext Editor, but when I try to insert an image in the *.pdf format, all I can see is an icon indicating a missing image.
Does anybody know if this is a matter of changing the display options or maybe this format is not supproted?
Thank you very much in advance.
Sandra
I apologize!
In Arbortext Editor 6.1 M020, we began supporting a pdf file as a graphic. A single page of the PDF is used. If no specific page is designated, then the first page is used.
PDF files are not considered graphical images by Arbortext Editor.
I apologize!
Thank you!
I am trying to include a pdf as a graphic in my document.
What is the syntax needed to make that work?
Thanks!
