HTML stylesheet?
akamaruzzaman
HTML stylesheet?
How do I create my own HTML stylesheet/CSS/javascript? I am using a html dtd but I want to use my own stylesheet.
Hi Anisah,
You can use a FOSI stylesheet to format an HTML document just as you would an SGML or XML document.
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
"WYSIWYG is last-century technology!"
Are you using Arbortext Editor with Styler? If so, then you can specify HTML styling.
Another alternative is to use XSL-FO style sheet, especially if you are using Styler or Arbortext Publishing Engine to format your documents.
Tim
Hi Anisah,
Good luck!
Suzanne Napoleon
www.FOSIexpert.com
Hi Anisah,
Were the previous answers what you were looking for, or did you need any specific information on this?
Feel free to mark one of the answers as 'Correct' or post here with your follow-up questions.
