Here is the error message
SindyYoung
2-Explorer
Has anyone seen this error and can you point me in the right direction to resolve it. I can't find anything in the help files that deal with this. If I open the document up in SGML Source, there is no entity file that is preventing up from deleing a row in a table. We can add rows above or below this particular row in the table and delete it just fine, it is just this particular row that we get this error message on. We are using Epic Editor 5.3 M120
[cid:image001.png@01CA9A6D.515D1D10]
Linda Shashani
Tools and Technology Team
AWS TSS Technical Publications
linda.d.shashani@boeing.com
MC 8A-42
(253) 657-6971
NOTICE: This communication may contain privileged or other confidential information. If you are not the intended recipient (or responsible for delivery of the message to such person), or believe that you have received this communication in error, please do not print, copy, retransmit, disseminate, or otherwise use the information. Also, please indicate to the sender that you have received this e-mail in error and delete the copy you received. Thank you!
You should open a call. Any error message that either says "internal
error" or refers to a location in the C or C++ source is something that
should not appear to a customer. And your message does both. There is
something wrong inside the code. It could be triggered by something in
your setup, but there is definitely something wrong in the code.
John Dreystadt
Software Development Director
Arbortext - PTC
734-352-2835
Hi Sindy-
Can you include the table markup, and an indication of which row
triggers the problem?
--Clay
