How do I get the update to IsoDraw CADProcess 7.2?
SusanDeLucia
Is version 7.2 available for IsoDraw CADProcess? Is it difficult to get the update?
IsoDraw 7.2 was released in May. M010 update is planned for September.
If you have active maintenance contract, just go to http://www.ptc.com/support/index.htm and click Order or Download Software Updates. You'd also have to get a new license file too.
Hello!
I also would like to note the following, the citation (from "(7.2 F000) Arbortext IsoDraw Release Notes"):
"Arbortext IsoDraw 7.2 F000 installs as a complete package that is separate from older versions of Arbortext IsoDraw you might have on your system. If you have Arbortext IsoDraw 7.1 (or older) installed on your system, installing Arbortext IsoDraw 7.2 F000 will not remove, replace, or otherwise affect it. After you install Arbortext IsoDraw 7.2 F000, you can still run the 7.1 (or older) software. You can also run it concurrently with this new 7.2 F000 release."
