Hello all,
I am new to PTC Community i just started to configuration of Arbortext Editor with small tasks.
The menu_delete function is perfectly working for me on some cases but there is one more thing that i should disable also in Arbortext 6.1 Editor dialog.
How should i delete the 'X' menu item on ArborText editor, what is the menu item name of this item ?
Could you please tell me ? I couldn't find it on the reference somehow, maybe not get in deep...
Any help would be appreciated, many thanks in advance!
One approach we used was to define a callback in our startup ACL code to manage the user's use of the X button and other quit actions
session_add_callback('quit', 'CheckQuit', 'PREPEND');
Where CheckQuit had the form (parameter "code" is not used)
function CheckQuit(code) {
if (modified()) {
### Do what you need here
set modified=off;
if (modified()) {
set modified=off;
Hi Oğuz,
Were you able to get this accomplished using Robert's information?
If so, feel free to mark his answer as 'Correct'/ Otherwise, let us know what other questions you may have.
Thanks!
