According to PTC documentation with content management systems track changes can be only applied to single object . If the tagging for a change tracking change affects more than one object, then the system will not interpret the change tracking information correctly.
Any suggestions/workarounds?
Enable change tracking on, do authoring with couple of add, modify and deletes and while checking in it gives the error (Arbortext editor 5.4 M70)
http://www.ptc.com/cs/help/arbortext_hc/ae54m090_hc/index.jspx?id=help5078&action=show
