How to put elements on different pages into one same page
ptc-5110902
Hello all
I would like to know the way in Arbortext Styler how to put elements into one page.
I made 8 element contents all with "hazardstatement" in Arbortext Editor and when its published in PDF, each hazardstatement shows up on different pages. (In total, 8 pages of hazardstatements with a lot of unnecessary blank space.)
All those 8 element contents in one same page to show it concisely with a stylesheet.
I hope to hear your advice.
Kind regards,
Tomomi
hazardstatement tends to have a "keep together" rule applied. This is because you don't want someone to read your hazard statement but miss an important line of text which has rolled over to the next page.
Try removing the "keep together" rule and see if that helps.
Removed the keep together rule and it worked to separate them.
Thank you for your help.
Kind regards,
Tomomi
