How to use Proxy with GET method for Arbortext Editor 6.0
ptc-5110902
Hello all,
I have an error with Arbortext Editor as follows.
My assumption is that it could be sorted out by using Proxy server with GET method.
Is it correct?
■ Error
 The public Schemas/DTDs on Web can not be loaded in the environment with Proxy server
■ Environment
 Software:Arbortext Editor 6.0
 Proxy Port used:15080
 Others:All correspondances without used Proxy is disconnected from the Internet by FireWall
■ Details
 I checked "http communication" and turned out that HEAD method to confirm the external schemas/DTDs is taken to #15080 port, though the GET method to actually obtain them is taken to #80 port.
Thank you very much.
Kind regards,
Tomomi
0 REPLIES 0
